what would happend in secondary voltage of a transformer if just icreasing #of turnes in primary of a transformer
As they said above, if you increase the number of turns on the primary, and don't change the applied voltage, you lower the volts-per-turn, which has the same effect on the secondary.what would happend in secondary voltage of a transformer if just icreasing #of turnes in primary of a transformer
