Today I came across a job with the following: Transformer rated at Y - Delta. 120/208 primary 3 Phase - 480 Volts Secondary.
3 wires on primary NO nuetral 120/208 Volts. Secondary 480 Volts. This transformer was not grounded. What is the correct way to ground this type of an installation? I also believe that a Delta - Delta should have been used. Any help is appreciated. P.S. This is not part of any service , just an add on in a location where 480Volts is required.
