hisham1986
- KSA/Riyadh.
Dear All,
I have found two unseperable definitions whenever i tried to know what percentage impedance means for a transformer.
First Definition:
Percentage impedance is the voltage drop on the secondary winding at full load in a transformer due to the winding resistance and leakage reactance and is expressed as a percentage of the rated voltage on the secondary winding.
Second Definition:
It is also the percentage of the normal terminal voltage at the primary side that is required to circulate full load current at the seondary side while the secondary side is short circuited.
The problem is that i am facing a trouble understanding whether these two definitions have to do something with each other,are they kind of related or do they share a common sense between each other and maybe am not seeing it? what is the relation between these two definitions?
Could anyone please help???
Thank you.
First Definition:
Second Definition:
Thank you.
