Using the table 450-3B to fuse a CPT, where the CPT is under 600 volts. Can I fuse the primary side using the Primary only 125%-167%-300% respectively and also fuse the secondary side using the Primary and secondary protection values 125%-167% respectively?
I believe this to ok due to the primary only needs protection?
