Stevenfyeager
- United States, Indiana
- electrical contractor
Transitioning from pvc to liquidtight, I use threaded liquidtight fittings plus a female pvc threaded fitting. But if I use 2", my supply house only has metal liquidtight threaded fittings, which present a bonding issue plus availability. On a house service, running pvc conduit outside from the meter to inside the house, I would like to transition to liquidtight once inside, to the panel. Is it ok to just slip liquidtight inside couplings and strap tightly ? I realize it's not a glued fit. Or is that a 'rigged' job ? Thanks
