Transition through Skirt
Cletis
OH
I'm running some flex through a non plenum ceiling (above acoustical grids) when I transition up through the skirt into the RTU when exactly do I transition from flex to seal tight??
Right where seal tight crosses roofline ?
slightly before or slightly after or does it really matter at all? Where does it go from damp location to dry location ????
Is this a roof penetration? Normally the penetration would be with RGS and a pitch pocket by the roofers. Transition your flex to the bottom of the RGS in the ceiling then RGS to sealtite out on the roof.
-Hal
When you go through the skirt are you going directly into the interior of the RTU ?
