Transocket bonding question
rkloehn
New member
US
Guys i have a 400a transocket for a PV system and i have a bonding question. Transocket is mounted outside. Next to the transocket is a 400a disconnect and the two are connected together with two 2" rigid nipples (parallel feed). I have grounding bushing on the disconnect side. Out of the disconnect are two 2" pvc that run into the building underground. How would you go about bonding this system?
Sent from my SM-G920R4 using Tapatalk
