Im doing a room addition. The homeowner asked my to look at a three way in which he had replaced the old light it controlled. Upon replacing he noticed signs of excessive heat. There was black rings on the ceiling and he said the insulation on the wires appeared slightly charred. I inspected the light and saw the rings but it was hard to tell which wire was heating up because the old insulation was stripped back a little more and he had taped them.
The house was built in the 40's and they used steel flex. All conductors on the three ways were blue and each common had a knot in the wire. After doing a search here I found the traveling bus three way thread which really helped me figure out that is the method they used.
I read in the Traveling bus thread that this is a legal method. Anybody have any input if this method could have caused the heat in the fixture. Or do you think it could have been a bad connection or something with the old fixture. Thanks for any replies.
