Hello to all.
Very informative forum.
I am wondering if the interior wiring in a home (downstream of the main circuit breaker panel) can be damaged due to overhead electrical service wires shorting at the exterior mast/weather head after a tree fell on service wires? After the tree fall incident on the service mast, a minor fire occurred at the main service panel in the basement, charring some wiring near the panel only. Also wondering if re-wiring of entire house would be necessary, as the homeowner is claiming.
Finally, would questionable pre-existing bonding and grounding details at the main service panel have an effect on the house wiring as a result of the incident and the path of the fault current that occurred.
Thanks.
Thanks.
