In a residential application,the inspector turned us down for trimming the bottom of a plastic device plate. We trimmed the plate about 1/4" to fit above the back splash of a kitchen counter.While it is not a common practice for us to do this, we did so because the back splash was raised to meet a serving counter. We were careful to make a clean cut so to fit tightly against the formica back splash.This was the first time we have been turned down for such a situation.
Trimming plates of device installations has not been an uncommon practice of ours.It is done usually to fit against door casings where space is a minimum or a wider trim has been used as an after thought by the customer.
The inspector supported his rejection to sections 110.12(C) and 404.9(A). After reviewing and contemplating these sections - We are still uncertain as to the violation and the intent of the code/AHJ.Thank You for opinion and view.
