Um, you won't have any trips at 20% loading. If a fault occurs the current will be high enough to power the trip units to trip the breaker.
But to answer your question, sort of, yes, same deal with Amptectors, nothing functional at less than 20% load, actually migh tbe closer to 30% for those. It is a matter of the CT's really, no output below a certian load. That is one nice thing about AC PRO's, the CT's they use still provide a usable output at 10% loading, some testeing shows closer to 5%, you don't ever have to change CT's or rating pugs for different loads and all the functions can be enabled or disabled for whatever your needs are. All simple things to do, no idea why the OEM's don;t design all trip units that way (Actually I do know, just don't want to be the one to say it
