Triplex for RV service
Hi! I was wondering if someone could help me comply with code on this......
I have a RV site that I would like to run power to....the only problem is it's 550 feet from my panel. I would have to run overhead and I have used some voltage drop calculators- maybe someone can verify wire size if I want to have at least 30A available at the other end?
And, I am correct in my understanding that I need to run a ground wire from panel to RV disconnect AND install ground rods/loop at the RV end?
Thank you in advance....
I am closing this thread, in accordance with the Forum rules. This Forum is intended to assist professional electricians, inspectors, engineers, and other members of the electrical industry in the performance of their job-related tasks. However, if you are not an electrician or an electrical contractor, then we are not permitted to help you perform your own electrical installation work.
If I have misjudged the situation, if for example this project is related to your work, then send me a Private Message. If you can show me that I am wrong, and that you are a licensed electrician (or at least a licensed apprentice), then I will reopen your post, and offer an apology for the delay and inconvenience.
A reminder to all members, if you see a questionable post, feel free to report it by clicking the
button at the bottom left corner of the post.
