Triplex From the House to Garage
I would like to use TriPlex or QuadPlex as an over head feed from the house to the garage. It would be considered a branch circuit. Is this permitted and what are the applicable codes that permit it. If not, what are the codes that do not allow it.
Thanks for your help
Look at Article 396. I don't think you will find any listed triplex or quadplex cables. It is my opinion that the code does not require the use of a listed cable but many AHJs prohibit those cables based on lack of a listing. I base my opinion on the list item in Table 396.10(A) which reads, "Other factory-assembled, multiconductor control, signal, or power cables that are identified for the use". It is my opinion that the cables in question are "identified" for the use.
