Dennis,
I am curious where the insert, and concept of using a ferrite that you posted came from? Was the problem you mentioned with a TV related to an AFCI nuisance trip?
When an AFCI is being upset by some electronic device, and higher frequency interference is suspected, It has been recommended that an EMI filter be applied to the offending device.
By EMI filter I refer to a "choke coil" plus capacitor type filter. A good quality filter of this type can attenuate frequencies in the range that an AFCI is most susceptible to.
A ferrite is usually only effective at much higher frequencies. While they can be very effective at reducing interference in the megahertz range I would be surprised if they helped a nuisance trip of an AFCI?
