I repiped and pulled new wire to a 3 phase disconnect and installed a new disconnect. I have a rotation meter so my phasing is the same. The disconnect feeds a transformer and then the machine. I used the existing breaker that fed the disconnect. At the end of the day they shut the disconnect off that feeds the machine. Now the Majority of the mornings when they turn on the disconnect the breaker trips. I am starting with replacing the breaker but am a little lost after that, is it related to the work I did which I inspected the best I could without pulling all the wiring out. Or is it just timing and something is going wrong with the machine or transformer. After they reset the breaker the machine has run perfectly all day every day. Thank you.
