Riograndeelectric
- Lakewood Colorado
OK I had a service call this morning on an office Loft. The building is a 2 story old warehouse converted to Office condominiums in the 1980s. All wiring is either EMT exposed or type AC cable in concealed walls. Most of the home runs are type AC cable directly to the panel.
There is a small galley style kitchen
There is a GFCI installed on the wall of the kitchen that then feeds a counter top outlet then feeds a Peninsula outlet. The wire that feeds the GFCI is Type 12-2 AC cable no shared Neutral
every Morning when the Employees come in and turn on the overhead lights the kitchen GFCI outlet trips.
After resting the GFCI, it is fine, you can turn the lights off and on again, and the GFCI will not rip.
The lights that trip the GFCI are line voltage track with no dimmer switches.
All lighting in the office is feed from 3-wire type AC cable.
I took the GfCI outlet out, rang out all the circuit, and verified it is not part of multi wire branch circuit or that the GFCI was not feeding any thing other than the Kitchen.
Any one has any idea why the GFI trips only in the morning when the light are turned on by the wall switch?
The owner told me this has been going on for several years and that another Electrician had replaced the GFCI outlet last year
