wayne123
- North Carolina
I installed 2 GFI recept in a residence.the problem i ran into was when i went back to test the recpts THAT WAS FED FROM THE gfi.,i found that when i tested the load side of the recpt ,hot to ground, that it tripped the GFI. WHEN I TESTED THE RECPTS -HOT TO N., THE CIRCUIT WAS FINE. WHAT MIGHT BE THE PROBLEM?
