hi guys. the lights do not work and i thought he might be wrong but maybe not.
Jim I dont know why i didnt think of that thanks i will ask him to check it out.
You likely have a dead line as mentioned. Disconnect the load and check voltage to ground again (with a low impedance meter) and you will have 120 on the good line and nothing on the other if this is the problem.
5v difference seems odd though. That is almost like two legs of 120v on same side, but different voltage because of different loading on each leg.
Yeah, 60W light bulb from N to L, N to L2 sounds like a good idea. If that works, but there isn't ~208v, you're on same phase....
Or avoid all this complication and just use two of the channels on an oscilloscope and see the phases.
