brother
Had a call about a gfci tripping. Well at first I thought it was the 'equipment' that was the problem. The gfci works ok with other tools.
What they had was a '2 prong (no ground prong)' work light, mostly plastic. I think the light is a 'led' every time they turn it on, it 'trips' the gfci. I saw this myself.
i know a gfci can work without a ground, it just senses an imbalance of current between the 'hot' and neutral.
Is the light (led) it self causeing something here?? I dont see any way for their to be any 'leakage ' here. any help would be appreciated. I told the guys the gfci will stay because it works with other tools. I admit I have not check the wiring/polarity of the gfci, but my understanding is that the 'new' ones will not reset if wired incorrectly. This is a fairly new install, (within the last year).
Also they said they tested the led work light at another gfci and it worked fine. Maybe its just a manufacturer type/style problem, wont know until tommorrow. Any suggestions would be greatly appreciated.
