COELECTRIC
4 bedroom (all on top level), two story house with basement. The owner calls and indicates that power for receptacles and lighting is out in two bedrooms and one receptacle is out in the master bedroom. I checked voltage on output of each breaker (panel schedule was no help) and all were functioning properly. Pulled each receptacle and found no loose connections. Basement is finished, so no way of knowing how branch circuit gets up stairs. Any you guys have any tips or tricks you use to isolate the failure point? I also checked all the GFIs' just in case. Any help would be appreciated.
