Situation: Customer has older home with aluminum and some replaced copper wire. No problems in 30 years. Calls us and said that he came home from work and his power was out in one part of his house. No breakers were tripped. He went to his window a/c unit and turned it on. The rest of his house turned on. Another day he was sitting in his living room. He had an oscillating fan on. He said it began to slow down, then stopped. The other things in that part of the house turned off at the same time (i.e, tv, cable, refrigerator) He went to his window unit, turned it on, everything else turned back on. I had one of my employees check every outlet, attic connections and voltages at both load centers. He found one mis-wired receptacle. Thought possibly that was the problem. All checked out good at that point.
Originally, thought it was an open neutral; however, all outlets, etc had good voltages.
Any ideas as to what else can be checked?
Did anyone see Gremlins?
