I am trying to troubleshoot a residential branch circuit and am getting nowhere. I have breaker that won't stay set. I have determined that the hot conductor is grounded somewhere downstream from the panel. I have taken apart the devices that I know to be on the circuit(includes finished basement, living room, part of a bedroom) and nothing seems to clear it. The house was built in the 50's and is a mix of grounded and ungrounded NM cable. The circuit in question is 3 wire where it leaves the panel but am finding 2 and 3 wire mix in various boxes and lighting outlets that I've taken apart.The basement has a finished ceiling and I suspect there are some buried J-boxes thru out it. The problem arose out of the blue, everything was working fine and then nothing. It's a mixed bag of workmanship, one of the lighting outlets appears to have been oprerating with a switched neutral as opposed to a switched hot conductor. I am dealing with metal boxes, some are grounded some are not some have as many as double the alloiweable wire fill. Am I overlooking something simple? Any thoughts appreciated.
