The customer has one of their ckts in the kitchen that doesn't work. I found the Home Run (HR) box and installed a brand new GFCI Plug there. But, with the gfi plug installed, I was reading 123v from Hot to ground AND 117v from Neutral to ground. I was also reading 6 volts ACROSS the hot & Neutral on the plug.
I removed the plug and connected a piece of romex from the HR box to the next plug downstream - without the gfi installed - IOW, hard-wired from the HR box to THE PLUG downstream - and the rest of the plugs showed correct wiring, including that 2nd plug. I don't remember checking the voltage at the HR box WITHOUT the gfci plug installed.
Could it be a bad GFCI plug? Dunno what's going on... The voltage at the panel was all good.
Help... if you can! Thanks! Kirk
