hi
i'm going to try to explain the situation, & maybe somebody can give me some advice or direction on troubleshooting this situation.
2 weeks ago i get a call from a new customer about receptacles not working in his kitchen, i get there and the circuit in question has 3 receptacles (one in the dining rm area, then the frig & a kitchen counter receptacle) and everything is working fine, good voltage at all three receptacles & refrig was working fine, so i figured that one of the stab-in receptacle has a bad connection, so i changed the 2 stab-in receptacles with non stab-in receptacle ( wires under the screws). & everything was working fine when i left. friday the same customer calls & the the same problem has come back, so i get there, plug my circuit tester in the first receptacle & it say's hot & ground wire reversed, so now i check the voltage hot to ground 120 volts hot to neutral 50 volts, neutral to ground 70 volts, so i tear apart the second receptacle & recheck my voltage & it has returned to normal 120volts from hot to neutral at first & second receptacle, tester say's wired correct. so now i'm thinking i have a bad wire between the second & third receptacles. Just to make sure, i put a load on the first receptacle & the voltage goes back to 50 volts between h & n, & the circuit tester say's ground & hot reversed, when the load is applied take the load away and it reads normal. so next i go check the voltage at the breaker while under load & its 120 volts, & now its getting late & the h/o makes a comment about having new siding put on the house 3 month's ago ( this house is only 10 years old) so i go into the attic & i notice the nails the siders used are sticking out 3/4" past the 2x4 ( mounted flat on the gable end of the roof)& the electrician who wired this house stuffed 4 homeruns in a 1/2" crack between the gable end & a 2x6 nailer which were likely hit by the sider nailing . at that point it was 7:00 and the ho had to leave so i'll be going back this week. my thinking is a nail between the neutral & ground, i also meggered the circuits & found no bad readings. so maybe it's not a nail or maybe my megger is bad. Has anybody run into a problem like this before.
thanks
i hope this all makes sense
thanks
