Troubleshooting Question
td1236
California
Had 2 lights that were flickering, in adjacent rooms. Checked voltage, checked connections, switches etc... Everything seemed to be fine. I Replaced the 2 lights , and the flickering stopped, then a day later they started flickering again.
Anyone have any similar experiences?
Thanks
Thanks
What kind of lights are they? Incandescent, compact fluorescent, or LED?
Sometimes, radio interference can affect LED lights. For instance, a garage door opener. I have a similar problem with LED bulbs in my bathroom. They have flickered now for years, maybe try a different manufacturer or different wattage if voltages look good.
If they are fed from the same circuit breaker, that is the first thing I would check/replace. Also, if a common circuit, I'd check wire nut connections along the way.
