JFletcher
- Williamsburg, VA
Are there any good/standard guides/books to this? Approx. 15-20% of our calls are SDW ("something doesnt work). Normally I try to figure out the most likely failure point, then work from there. This is pretty decent, but doesnt always work well. To wit:
P(problem): Overhead crane not working
LP (likely problem): Busted weathertight fittings on controller; corrosion
PF (problem found): Crane cord had a short in it in two places.
P: String of receptacles not working
LP: Tripped breaker, tripped GFCI, backstab failure
PF: Tripped breaker in adjacent tenant's panel; breaker tripped in a way not immediately obvious it was tripped
P: Sign light (plug and cord) not working
LP: Bad sign (verified good by plugging into different receptacle), open neutral (via plug tester)
PF: Bad breaker (owner used it as a switch)
P: Newly installed AFCI tripping
LP: Shared neutrals w/another circuit
PF: Shared neutrals in 2 places (still took a while to find out where)
P: Hallway light wired to 3 ways stays on after several switch cycles
LP: ???
PF: Both 3 ways had failed
P: All lights in x room dont work
LP: Bad switch, tripped breaker
PF: All bulbs blown out
Is there any book that has this kind of stuff in it? I always try to get as much info as possible, like "when did it fail?", "have you done any electrical work recently?", "is the breaker tripped?", if so "will it reset?", etc as I can, tho many times the information given is not helpful, thus the SDW call. Or is this kind of learning the school of experience/hard knocks?
LP: ???
