Coppersmith
- Tampa, FL, USA
- Electrical Contractor
I'm trying to formalize a system for inventorying service trucks with two purposes in mind: protect against theft or loss of inventory and tools; and keep the truck properly stocked.
I've seen some previous discussions of this and I'm really just looking for best practices based on what those here are doing, experiencing, or have researched. I'm trying to strike a balance between the cost of monitoring, the cost of losses, and the cost of not having a needed item on the truck. I'm also trying to decide what action (if any) I should take if I see take a truck's losses are significantly higher than average.
I think tool inventory is straight forward. There are a small number of expensive tools on the truck. I expect the tech to not steal or lose them. Tools will break and I expect the tech to tell me so they can be fixed or replaced. Every once in a while (how often?) we should count the tools and verify they are all present and in working order.
Bits, blades, and other expendables are not cheap and there are a small number on the truck. At minimum these need to be counted just to make sure they are in stock for when needed. Should they be monitored for loss or waste? I know electricians who use a fresh drill bit every day and throw away the partially used (but still serviceable) ones. Is it worth it to track that?
Material inventory is the hardest question. In the past I have just filled a service truck with inventory (mostly low value stuff, but it adds up) and sent a technician out into the field. If we have a big planned job like a service change, I will buy all the material and have it available for the tech to pickup at the shop. I also give the tech a credit card to buy whatever they need for their jobs. I monitor the purchases on the credit card basically looking for something odd that stands out.
I think we need to do a physical count (how often?) to make sure needed items are on the truck. I'm not sure it's cost effective to be concerned if some amount (how much?) goes missing. Perhaps we need to just worry about protecting the expensive items ($5 or more?).
Counting the truck is expensive in terms of labor hours. Somebody with a clipboard was to spend a couple of hours counting and entering data. Techs are notoriously bad at keeping track of items removed from and added to the truck. I could give them a barcode scanner and barcode everything but I would not trust the results. I have asked techs to keep a shopping list of items they are low on and it doesn't work well.
Perhaps the answer is to have a spare fully stocked truck available. On the designated inventory day, the tech brings his truck to the shop and swaps his truck for the spare. A lower cost employee can then spend whatever time is needed to fully inventory the truck head to toe, refill it, clean it, and get it ready for the next swap. A report can be generated detailing the inventory condition of the truck and a decision can be made if any disciplinary action needs to be performed.
As always, I'm looking forward to reading what the giant collective brain of this group has to say.
ETA: I had one tech who used my truck on weekends to do side jobs. I'm not sure if he was using my materials. I think he was using my tools and expendables. I had to make a surprise visit to his house to verify my suspicion. When the truck was not there on a non-work day, the truth came out. GPS tracking might have solved this.
ETA2: I had one tech who had a crash in the service truck and didn't tell me. I had to notice the damage on my own. He denied any knowledge of the damage. Truck swapping could check for this also.
