Can the clampon ground resistance tester be used on such an application as a truck unloading station truck ground lead? I just clamped on to three. (these are old facilities) Results: 1) low .18 ohm (ground reading) 2) 1000 ohms 3) infinity.
I am doing my research now on grounding services cause nyc is getting more strict on it. In 2008 videos Mike Holt says that he could not have tested his son's well casing grounding using clamp on tester cause there was no electric service brought to it. That is your case, right?
As Don stated the tool is designed to test grounding electrodes end it needs electric utility neutral wire to perform a test.
....Or change batteries in tester
