malachi constant
- Minneapolis
I am the engineer on a job in the early design phase and I am looking for some thoughts.
Have a building almost 100 years old in rural Minnesota - about an hour outside of downtown Minneapolis. The gear inside is probably 50 years old and is labeled 208V three phase - I think it is a 400A service. There are only two pole mounted transformers (on the same pole) outside the building. Utility says it is NOT a three phase service. There is a three-phase generator, only a few years old, that is integrated into the system as an emergency backup for lighting, pumps, freezers, etc.
What is going on? Both the utility and the other engineer here speculate it is three-phase power derived from a true two-phase source, but are unable to go into depth beyond that.
I intend to upgrade the service to 208/120V 1000A 3-phase 4-wire. My primary concern is that existing motors may not being compatible with the new voltage. I'm also concerned any time I meddle with a system of which I don't have a solid understanding.
Read some history on wikipedia ("Two phase") but not sure that is the same thing I have here.
Any suggestions on what Qs I can ask, what I should plan against, or if I have their maintenance staff open up some equipment what I would be looking for, etc etc? Much appreciated.
