I have a question regarding the TJI truss joists used in newer homes. You know the stuff, it looks like 1/2" particle board or "chip board" with heavier wood running along the edges. A customer is finishing his basement. He'll be putting in a sheet-rock ceiling rather than a hung ceiling. This means that all of my wires need to be run through the joists, and the existing wires that are stapled along the para-lam beam will need to be relocated to run through the joists rather than taking the shortcut below them. Question #1 : Can I notch the bottom of these joists rather than cutting the cables and finding some creative places to spot some j-boxes? Also, several walls have been framed out running the length of some of these joists, and the only way for me to get my wires down them is to drill through the top plate and the bottom part of the joist. Question #2: Is it acceptable to drill through these joists? I know this is not an NEC issue, more of a building code issue. But I figured some of you guys with more experience than myself in residential wiring may have come across this sort of situation before. ( I'm more of a commercial/industrial type of guy)
Thanks.
John
Thanks.
John
