davey5060hz
New member
I have an Acme T-2-53010-S general purpose 240x480-120/240V 1.0KVA transformer which is rated at 60Hz only on the nameplate. I bought this transformer in the US and I live in Switzerland. Winding rise is 115? C, insulation class 180. I would like to connect this transformer to 230V 50Hz to get 115V 50Hz out of it. The load will probably not exceed 600 watts or 600VA. I have contacted Acme and they say derate the input voltage proportionally but this is not really practical for me. In your opinion, can I operate this transformer without problem at 230V input by ensuring load stays at 600VA or lower?
Actually looking for someone who knows this particular transformer and might know what its headroom to saturation would be. Actual mains voltage usually measures to about 227-228 V. I do have an o-scope and current probe standing by to test this transformer as soon as I get some small parts on order from the US. Hoping to not see a distorted current waveform and even if it is slightly distorted (causing secondary to be same), how serious is this on most normal loads?
