Shackled Designer
- Decatur, AL USA
The background for the questions below is industrial panel design involving a primary panel that will supply at least one subpanel.
1) Is it correct to say that a supply line from the main panel to a subpanel is considered a feeder from the perspective of that subpanel?
2) If within the main panel I protect the supply to the subpanel with a branch circuit protector, does that mean that the subpanel supply line is not considered to be a tap (and therefore not subject to tap rules)?
3) If the supply to the subpanel is not a tap as I have described it in question 2, are there any other NEC considerations for the wire run between panels that I need to bear in mind beyond sufficient OCP for the subpanel's load?
Kind regards,
Shak
Kind regards,
Shak
