srwhitlock7
New User
- Arizona
- Special Systems Engineer
Hello all and Thank you for any recommendations to start!
I am trying to figure out how to power up Dimmer Switches without the need to physically connect lead wires for every switch time after time. I am wanting to be able to program multiples of these to Smart Home systems in upwards of 100 per day. In my head I have a thought of something this I think would work but cannot get the end result. I think that by running 18 guage wire into a box and be able to "liven" a clip type design will allow me to be able to press in the dimmer switch where the screws are clipped in. This in theory should be able to power the switch, allow me to be able to perform the programming and then pull the switch back out and be able to do this multiple times.
I have the SnapPower faceplates in my house that utilize a similar method where the faceplate clips onto the outlet and is able to power the lights on the faceplate. I want to create something like this, but backwards. Where the clips will be live with a switch to power on and off but will be able to power any receptacle that is pushed into the gang box when the power is live.
Sorry if I talked in circles there, but hopefully I can get a few ideas from you to try and figure out something.
Thank you again,
Shayne
Thank you again,
Shayne
