Mustwin351
- Texas
The other day I had to change a ballast on a can light. Turned off the switch to kill the light to change it out. I opened up the j box of the can light that the ballast is connected to in order to disconnect the wiring to the ballast. I never opened the joints inside the junction box just removed the wires to the ballast. So the only exposed wires were the ones that went to the old ballast. In doing so the grounded conductor got away from me and touched the box with a decent spark. This is not a multiwire branch circuit by the way. With my multimeter I read 1.5v from the grounded concutor to the j box. From the hot I had 0 volts to ground. A current reading from the grounded conductor to the can showed 2.5 Amps flowing. I’m thinking by touching the grounded conductor to ground I simply created a low impedance parallel path for current to flow for lights that are in another room. My question is if I accidentally touched the grounded conductor while my body is grounded would my body provide enough resistance for it not to be a shock hazard? Since the joints on the grounded conductor were not opened I would think in theory it would not be a shock hazard. Your thoughts?
