SforresterBHC
- Bullhead City Az
- Maintenance Electrician
Hello all, I work for a city utilities department, and I have a project I am working on concerning ATS.
I am trying to install ATS at all water distribution sites, all is good, except for 1. The site in question is fed from 2 sources, 1) 480v 400A 3 phase service from overhead powerlines that is used to power transfer pumps and 2 well sites close to the feed site, 2) a 120v/240v single phase 125A service from the street that is used for the main site 120/240v loads(lighting, RTU Cab, 208/230v AC, 120/240V sub panel on chlorine room, and recepts with a 240v welder recept in the work shop). The 2 well sites are no longer in operation and are completely abandoned, the 2 transfer pumps used at feed site are only 30A a piece. I want to set it up to only need 1 generator to power in a black out. My question is: is it more efficient to change the site over to being fed from the 3 phase 480v source with a 3 phase step down 120/208 panel and a couple buck-boost transformers for the 240v loads, or keep the 120/240v source and install a small transformer that only gets power when generator is in use that is also tied to a manual transfer switch to power RTU, Chlorine Room and lights only. First configuration would be simpler and straight forward IMO, but second could be less work and possibly cheaper (which is what I am told is the main factor in making this change).
