stew
- federal way,washington
had a simple troubleshoot today at a rehab center/assisted living facility. no power one room. ideal tester originally read open neutral with the light just trying to blink and very dim. a suspect outlet was removed and replaced just because it was very brown at the terms. the tester then read ground and hot reversed which was not the case. double checked at the panel and found a full boat in a 3/4 with a single neutral. checked some adjacent small offices and found that the lights had been dimming and other outlets in those room also checked hot neutral reversed. also the outlet prongs tested hot on both sides with a fluke hot stick. meter showed wierd voltages of 108 and some at 117 some at 85 which indicates to me a neutral problem,
had an attic acces so went up and followed the pipe to a shallow j box above. of course the bad neutral that was crispy critters was in there all covered up by the hots. Lets see is 7 -12 gage in a red nut ok? how about 7 neutrals,3 hots in ,6 hots out in a standrd shallow 4 sqaure grab ya? we cleaned up the neutrals and renutted correctly and added an extension. problem solved but i often wonder how contractors get away with this kind of stuff? a 3/4 pipe in 4 -1/2 inch pipes out and a 1/2 inch flex out and a 3/4 out. man what a mess!!!!!!!!!!!
what caused the ideal tester to read hot/n reverse? when it wasnt?
