Tv/ data outlet box or no box
rodriguezandy
Arizona
Is there a NEC code that requires a Jbox for television and data outlets in a commercial setting? Or can I just use a mud ring with a 1" conduit w/ bushings through the wall and stubbed out above the ceiling grid?
Nothing in the NEC,check what kind of wall it is, if its a fire rated wall you need to preserve the fire rating.
That makes sense, the wall is non fire rated so I should be able to just run emt down the wall without a box.
Thanks alot for your response, I am new to the forum, I didn't expect to get an answer so soon.
