TV height above fireplace
I think that the best source of information would be the instructions for the fireplace. Do you have access to that information?
We all know that the enemy of electronic components is heat. I would never mount any of my TV’s above a heat source.
Cable or satellite receiver, sound system, gaming consoles all produce heat and are often under an associated TV:p
Any properly-exhausting fireplace will draw air from the room, and not heat anything mounted above it. A simple test with one's hand while a fire is going will tell you if there is an issue. I have mounted many TVs above fireplaces and not heard of any issues.
Unless you put a blower on it to blow some heat into the room. But that is blowing air that is indirectly heated and is not the "exhaust" air that is coming out, plus the further it travels from the outlet the more heat it loses to the room, so unless you are right on top of the fireplace so to speak that air isn't too hot for something like a TV. Mantle (when present) does help divert any heat away from things on top the fireplace also.
If you mount it too high, you get a sore neck watching it. It happens to me at other houses. Must be I do not get the "good" chair. Mine is not above the fireplace for that reason alone. I go for what works for me, not what looks good in magazines!:D
Got a copy of the IRC (International Residential Code)? They list protrusions above the fireplace and the limits thereof.
If you mount it too high, you get a sore neck watching it. It happens to me at other houses. Must be I do not get the "good" chair. Mine is not above the fireplace for that reason alone. I go for what works for me, not what looks good in magazines.
I read in some journal on ergonomics that the optimum height of a wall mounted TV is to have the bottom of the screen at eye level when seated at viewing distance. This would mean that over a fireplace is too high except for very short fireplaces.
Ten years ago I thought I wanted my TV over the fireplace. I researched the web, the fireplace manual, mantel design, etc.
I mounted the TV six inches above the "builder" mantel and decided it was too high.
I lowered the mantel and the TV six inches. Still too high.
I wrecked out the mantel (and installed a small curio shelf @ 48" AFF to hang Christmas stockings) and lowered the TV twelve inches to around 52" AFF. I was still having to stand up to watch TV.
I put the TV on a stand next to the fireplace. I found a huge decorative mirror to put over the fireplace to cover the cut-in boxes and lag-bolt holes.
As far as I know, no restriction on mounting TV over fireplace except having to stand up to watch TV.
