Here is a question for you folks out there as it relates to a LV installation of coax wiring and tvs.
What does the code say about the min. height or distance required to the bottom of a TV set that is hung on a TV mount with the pipe that extends up and is secured to the unistrut in the ceiling. Commercial space.
Building inspector said 90" to the bottom of the tray that holds the TVs. When he was shown the units that hang below drop tile which can't get higher then say 78 to 80" he reversed himself and said he would allow those as they are in the corners of the room.
What does the NEC say about height to TVs?
Thanks.
Thanks.
