S Stevenfyeager Senior Member Location United States, Indiana Occupation electrical contractor Mar 9, 2021 #1 Can we put a tv outlet on stone wood burning fireplace ? Fire code. 1” air space ? 2” air space?
Little Bill Moderator Staff member Location Tennessee NEC:2017 Occupation Semi-Retired Electrician Mar 9, 2021 #2 I have put many outlets above a wood burning fireplace. I rough them in and leave the box for the mason to fix in place. This is all outside the firebox.
James L Senior Member Location Kansas Cty, Mo, USA Occupation Electrician Mar 9, 2021 #3 If the stone isn't cut flat, I suggest building out a flat surface out near the front of the stone so you can mount the t.v. Get an accordion style t.v. mount that can pull away a couple of inches if need be
