jrc0109
- Orlando, FL
- Retired
Can the TV power cord on a wall mounted TV be run through an interior wall to pull into an outlet on the other side of the wall?
Of course it can.Can the TV power cord on a wall mounted TV be run through an interior wall to pull into an outlet on the other side of the wall?
I believe the door and window prohibition does not include running a power cord exposed in a pass-through, which is very different from running one through a doorway with a door, a window, or a hole through a wall.I don't know why this kind of prohibition exists. There is nothing really inherently unsafe about the type of installation you are talking about. It seems to me that if you had a half wall between say a kitchen and a dining room with a counter on top of it, the code effectively prohibits you from putting a coffee pot on top of the countertop on the dining room side and plugging it into the kitchen side. This is one of those horribly written pieces of code that was not ever really thought through.
That's what should be done, using a standard wiring method such as NM and an old-work boxThere is nothing to prohibit you from installing a receptacle on the same side of the wall as the TV that is fed from the receptacle on the other side of the wall though.
How is that not a hole in the wall? Especially if it has an accordion type door.I believe the door and window prohibition does not include running a power cord exposed in a pass-through, which is very different from running one through a doorway with a door, a window, or a hole through a wall.
You can't stop noncompliant use after the installation.Although wrong I have been asked to put an ent conduit in for hdmi and have seen the power cord ran down with the hdmi later on.
The problem is is that a lot of rules in the electrical code are extremely arbitrary and have almost nothing to do with safety. There's nothing inherently unsafe about running the power cord inside a piece of ENT in the wall with the HDMI cord. Arguably it's considerably safer than running it on along the outside of the wall which is okay.Although wrong I have been asked to put an ent conduit in for hdmi and have seen the power cord ran down with the hdmi later on.
