Re: Twin Breakers in Panels
From the UL White Book
CLASS CTL PANELBOARDS
Class CTL panelboards incorporate physical features which, in conjunction with the physical size, configuration, or other means provided in Class CTL circuit breakers, fuse holders, or fusible switches, are designed to prevent the installation of more overcurrent protective poles than that number for wihch the device is designed and rated.
CIRCUIT BREAKERS, MOLDED-CASE AND CIRCUIT BREAKER ENCLOSURES (DIVQ)
CLASS CTL
Some curcuit breakers are not provided with a means to prevent their installation in Class CTL assemblies. These circuit breakers are for use in old style, non-Class CTL equipment and are marked "For Replacement Use Only, Not CTL Assemblies."
When I first broke into this industry, I was taught those kind of breakers were for use anywhere we needed them...
I know a little better now.
