matthewswain
- Virginia Beach VA
- Electrical Contractor
I want to feed two 200A x ray circuits directly from a 400A Siemens safety switch that has double lug for line and load. This is not a service or tap. I want to know if I can run two 200A circuits in parallel via one 400A circuit through the safety switch. The line is one 600kcmil circuit (via transformer) with two 250kcmil (for voltage drop x ray). All I can find in NEC atm is 240.8 statimg equipment needs to be listed. Siemens spec sheet does not specify but has double lug. I am concerned that the AHJ may consider this a tap. Can I run two 200A circuits in parallel from a 400A switch without installing two 200A disconnects within 10'
