andro_Peter
New User
- Montreal (Canada)
- IT tech
Hello,
First of all, I'm not an electrician and don't expect to do the connection in the breaker panel. I just want to install everything and then call an electrician.
So I want to install two baseboards in parallel with one T-Stat in the basement of an old house.
The following setup gives each baseboards 240V but they don't heat: baseboards are 1000W each
1) 240V runs from a 15A breaker to a Double-pole Tsat
2) Runs out to junction box
3) Out of junction box, one cable to electric baseboard 1 and one cable to electric baseboard 2
If I install them in a serial setup, everything is ok but they do not heat as full as they should do.
Thank you folks
Thank you folks
