- Lockport, IL
- Semi-Retired Electrical Engineer
I am doing an independent review of another person?s design. I found two things I know are ?wrong,? i.e., bad designs, but I cannot find the specific NEC article that would forbid them. I do know that a feeder must have an ampacity no lower than its calculated load ? 215.2(A)(1). In this instance, I wasn?t given the feeder sizes, but I have already written that up, so it is not my present issue. So, are these two items violations?
- A 225 amp MLO panel that has a 116 amp calculated load is protected by a 100 amp upstream feeder breaker.
- A main service panel whose current rating is not shown on the drawings has a calculated load of 875 amps. Its main breaker is rated 800 amps.
