peterwire
- los angeles, california
i have a load big enough that requires two 1/0AWG cables in parallel. NEC 310.4B allows to install both conductors if 1) are the same lenght; 2) have the same cond material; 3) are the same size; 4) have same insulation; 5) are terminated in the same manner.
how do i terminate them on a circuit breaker with one entry per phase?
I was told to use a dual barrel lug, but all i can find online seems to be for bolted connection (see picture attached) not a female connection for the breaker. could you help me? thanks!!
