arjo_reich
My friend hired an electrician to wire two dedicated 20 AMP circuits for his new home theatre in the basement. The electrician completed the work in a way I thought was rather interesting and, since I consider the members on this board to be the professionals, I was wondering if I could get your opinions on his wiring method.
Rather than using two 20 AMP breakers and running two circuits, he installed a double pole 20 AMP and through the EMT he ran two hots - one for each phase - with a common neutral and ground. The first double gang receptacle enclosure takes one hot, the common ground and neutral and the second hot is ran through to the second double gang enclosure. The distance between the two enclosures is about two feet...although I doubt that matters much.
Would you run it the same way? Why do you think he did it like this?
My personal opinion is that he did not run two dedicated circuits as the work-order stated and instead ran a single, "double-phased" (is that the correct terminology) circuit.
Thank you in advance,
R. Joe Reich
R. Joe Reich
