wondervamp
- SF Bay Area
- Shop technician
Hello,
I have a GFCI circuit in kitchen as follows:
There are four plugs on this circuit, the first is correctly wired with a GFCI receptacle with line coming in to the line side and load side out to next plug which is a duplex plug, on to the next plug which is also a duplex, but the last one is an old GFCI plug which I just plan on keeping because I am being cheap but I want to make sure it is wired correctly. I know that it makes no sense if wiring new this way with another GFCI plug as a load and is a waste of money - but in my case, it is already there and I don't want to change it out until I remodel the kitchen.
Here are my TWO QUESTIONS:
1) this end of line GFCI plug - does it get fed at the line or load side?
2) does each plug on the GFCI circuit have to be 20A rated - GFCI plug AND duplex plugs?
Thanks
Thanks
