- Tennessee NEC:2017
- Semi-Retired Electrician
If you had a 400A/320A service with two 200A panels, and you wanted to power both panels from generator power, could you use an interlock in each panel, along with an inlet for each panel, and have a generator for each panel? I know this can be done, but my question is, will the fact that the neutrals will not be switched be a problem? Assume the generators are unbonded.
