Two holes on each side of 4" square box
Two holes on each side of 4" square box -- what are they for?
Originally those little holes were so the manufacturer could screw on some sort of brackets. Nowadays the brackets are spot welded on but there is some sort of inertia going on.
I would like to point out that some of these holes, in the 4 square boxes are the right size to simply tap for a 10-32 grounding screw. If you have the proper grounding screw, such as the Dottie 10-32 ST, these will self tap in one of those little holes.
~Peter
In the rare event that you want to use the box as old work, you need the brackets to hold it from falling in the wall, hence the screw holes.
They are good for tapping and using the ground screw in them when you have back to back boxes.
c2500
I have never seen those holes come threaded though.
~Matt
Tap them.
Before dimpled EGC screw holes...they were flat - much like the world was.
Shooting a 1900 to a steel beam left no place for a screwed in EGC ~ sure you could use a clip, but the world was flat then and clips didn't exist.
It's true.
:grin:
